Mobile guides
Back to Select settings
You can avoid data traffic when abroad by deactivating data roaming. No connection to the Internet via the mobile network can then be established. You can still use WLAN even though data roaming is deactivated.
Step 1 of 5
Slide your finger left on the display.
Press Settings.
Step 2 of 5
Press mobile network.
Step 3 of 5
Press the field below "Data roaming options".
Step 4 of 5
Press roam or don't roam.
Step 5 of 5
1. Find "mobile network"
Press Settings.
3. Return to the Home screen
