Connect to a WLAN
You can use WLAN as an alternative to the mobile network to connect to the Internet. Your mobile phone doesn't use data traffic when connected to a WLAN. Have you forgotten your Swisscom WLAN password? You can find it here.
Step 1 of 6
Slide your finger left on the display.
Press Settings.
Step 2 of 6
Press WiFi.
Step 3 of 6
Press the indicator next to "WiFi networking" to activate WLAN.
Step 4 of 6
Press the required network.
Step 5 of 6
Follow the instructions on the display to key in security settings.
Press done.
Step 6 of 6
1. Find "WiFi"
Press Settings.
Press WiFi.
2. Activate WLAN
3. Connect to a WLAN
Press done.
4. Return to the Home screen
