Back to Settings & usage
Step 1 of 17
Slide two fingers down the display starting from the top edge of your mobile phone.
Step 2 of 17
Step 3 of 17
Press Security & location.
Step 4 of 17
Press Fingerprint.
Step 5 of 17
Press Set up screen lock.
Step 6 of 17
Press the required phone lock code and follow the instructions on the display to create an additional phone lock code.
Step 7 of 17
Press the required setting.
Step 8 of 17
Press DONE and key in the selected phone lock code.
Step 9 of 17
Press Add fingerprint.
Step 10 of 17
Press Continue.
Step 11 of 17
Press START and follow the instructions on the display to create the phone lock code using your fingerprint.
Step 12 of 17
Press DONE when your fingerprint has been registered.
Step 13 of 17
Press the return icon.
Step 14 of 17
Press Screen lock.
Step 15 of 17
Key in the current phone lock code and press None.
Step 16 of 17
Press YES, REMOVE.
Step 17 of 17
1. Find "Security & location"
2. Create phone lock code using your fingerprint
Press Fingerprint.
Press Continue.
Press Screen lock.
Press YES, REMOVE.
4. Return to the Home screen
