Mobile guides
Back to Settings & usage
Activate or deactivate call barring
You can block certain types of calls such as incoming calls when you're abroad.
Step 1 of 9
Press the mobile phone icon.
Step 2 of 9
Press the menu icon.
Step 3 of 9
Press Settings.
Step 4 of 9
Press Calling accounts.
Step 5 of 9
Press the field below "Settings".
Step 6 of 9
Press Call barring and wait while the current settings are retrieved.
Step 7 of 9
Press the required barring type.
Step 8 of 9
Key in your barring password and press OK.
Step 9 of 9
1. Find "Call barring"
Press Settings.
2. Activate or deactivate call barring
3. Return to the Home screen
Get information on...
Or select...
Another device
