Customer Center E-Mail + SMS TV myCloud Find a Swisscom shop Contact
Mobile guides
You can limit your data usage when abroad by deactivating data roaming. No connection to the Internet via the mobile network when abroad can then be established. You can still use WLAN even though data roaming is deactivated.
Step 1 of 7
Slide two fingers down the display starting from the top edge of your mobile phone.
Step 2 of 7
Step 3 of 7
Press Network & Internet.
Step 4 of 7
Press Mobile network.
Step 5 of 7
Press Roaming to activate or deactivate the function.
Step 6 of 7
Press OK.
Step 7 of 7
1. Find "Mobile network"
Press OK.
3. Return to the Home screen
