Back to Settings & usage
You can set your mobile phone to use face recognition as phone lock code or to authorise iTunes and App Store purchases.
Step 1 of 11
Press Settings.
Step 2 of 11
Press Face ID & Passcode.
Step 3 of 11
Press Set Up Face ID.
Step 4 of 11
Press Get Started and follow the instructions on the display to add your Face ID.
Step 5 of 11
Press Done. If you haven't previously selected a phone lock code, key in a code of your own choice twice.
Step 6 of 11
Press the indicator next to "iPhone Unlock" to activate or deactivate the function.
Step 7 of 11
Press the indicator next to "iTunes & App Store" to activate or deactivate the function.
Step 8 of 11
Press the indicator next to "Apple Pay" to activate or deactivate the function.
Step 9 of 11
Press the indicator next to "Password AutoFill" to activate or deactivate the function.
Step 10 of 11
Press Turn Passcode Off and key in your phone lock code.
Step 11 of 11
Slide your finger upwards starting from the bottom of the display to return to the Home screen.
1. Find "Face ID & Passcode"
Press Settings.
2. Add Face ID
3. Select Face ID settings
4. Deactivate use of phone lock code
5. Return to the Home screen
Get information on...
Or select...
Another device
