Mobile guides
Back to Settings & usage
Activate or deactivate use of PIN
The PIN protects your SIM from unauthorised use should your mobile phone get stolen. If use of PIN is activated, it needs to be keyed in when you turn on your mobile phone.
Step 1 of 6
Press Settings.
Step 2 of 6
Press Mobile Data.
Step 3 of 6
Press SIM PIN.
Step 4 of 6
Press the indicator next to "SIM PIN" to activate or deactivate the function.
Step 5 of 6
Key in your PIN and press Done.
Step 6 of 6
Slide your finger upwards starting from the bottom of the display to return to the Home screen.
1. Find "SIM PIN"
Press Settings.
Press Mobile Data.
Press SIM PIN.
3. Return to the Home screen
Get information on...
Or select...
Another device
