Back to Settings & usage
Connect a Bluetooth device to your mobile phone
Bluetooth is a wireless connection which you can use to transfer files between two devices or to establish a connection to other devices, such as a wireless headset or keyboard.
Step 1 of 5
Press Settings.
Step 2 of 5
Press Bluetooth.
Step 3 of 5
Press the indicator next to "Bluetooth" until the function is activated.
Step 4 of 5
Press the required Bluetooth device and follow the instructions on the display to connect the Bluetooth device to your mobile phone.
Step 5 of 5
Slide your finger upwards starting from the bottom of the display to return to the Home screen.
1. Find "Bluetooth"
Press Settings.
Press Bluetooth.
2. Activate Bluetooth
4. Return to the Home screen
Get information on...
Or select...
Another device
