Activate or deactivate WiFi Calling
When WiFi Calling is activated, you can make and receive voice calls over WLAN when you're in an area with poor or no network coverage. To activate WiFi Calling, you need to connect to a WLAN and activate use of 4G for voice calls and activate mobile data.
Step 1 of 6
Press Settings.
Step 2 of 6
Press Mobile Data.
Step 3 of 6
Press Wi-Fi Calling.
Step 4 of 6
Press the indicator next to "Wi-Fi Calling on This iPhone" to activate or deactivate the function.
Step 5 of 6
If you activate the function, press Enable.
Step 6 of 6
Slide your finger upwards starting from the bottom of the display to return to the Home screen.
1. Find "Wi-Fi Calling"
Press Settings.
Press Mobile Data.
2. Activate or deactivate automatic use of mobile data
3. Return to the Home screen
Get information on...
Or select...
Another device
