Back to Settings & usage
Write and send MMS
An MMS is a message which can contain pictures and other media files and can be sent to other mobile phones and e-mail addresses. If you can't send and receive MMS as soon as you've inserted your SIM, you need to set up your mobile phone for MMS.
Step 1 of 11
Press the message icon.
Step 2 of 11
Press the new message icon.
Step 3 of 11
Press the field next to "To:" and key in the first letters of the required contact. Matching contacts from the address book are displayed.
Step 4 of 11
Press the required contact.
Step 5 of 11
Press the text input field and write the text for your MMS.
Step 6 of 11
Press the gallery icon.
Step 7 of 11
Press All Photos and go to the required folder.
Step 8 of 11
Press the required picture.
Step 9 of 11
Press Choose.
Step 10 of 11
Press the send icon when you've written your MMS.
Step 11 of 11
Slide your finger upwards starting from the bottom of the display to return to the Home screen.
1. Write MMS
2. Select recipient
3. Write text
4. Insert picture
Press Choose.
5. Send the MMS
6. Return to the Home screen
Get information on...
Or select...
Another device
