Activate or deactivate GPS
You mobile phone can determine your geographical position using GPS (Global Positioning System). The information about your position is used by a number of applications on you mobile phone, such as navigation, the search function and the weather forecast.
Step 1 of 11
Press Settings.
Step 2 of 11
Press Privacy.
Step 3 of 11
Press Location Services.
Step 4 of 11
Press the indicator next to "Location Services" to activate or deactivate the function.
Step 5 of 11
If you deactivate the function, press Turn Off.
Step 6 of 11
Press the required application.
Step 7 of 11
Press the required setting.
Step 8 of 11
Step 9 of 11
The applications are only available if you activated Location Services.
Step 10 of 11
Press Privacy to save the settings.
Step 11 of 11
Slide your finger upwards starting from the bottom of the display to return to the Home screen.
1. Find "Location Services"
Press Settings.
Press Privacy.
2. Activate or deactivate GPS
3. Activate or deactivate use of GPS position for applications
4. Save settings
5. Return to the Home screen
Get information on...
Or select...
Another device
