Apple iPhone 11 Pro
Back to Settings & usage
You can set your mobile phone to use face recognition as phone lock code or to authorise iTunes and App Store purchases.
1. Find "Face ID & Passcode"
Press Settings.
Press Face ID & Passcode.
2. Add Face ID
Press Set Up Face ID.
Press Get Started and follow the instructions on the display to add your Face ID.
Press Done. If you haven't previously selected a phone lock code, key in a code of your own choice twice.
3. Select Face ID settings
Press the indicator next to "iPhone Unlock" to activate or deactivate the function.
Press the indicator next to "iTunes & App Store" to activate or deactivate the function.
Press the indicator next to "Apple Pay" to activate or deactivate the function.
Press the indicator next to "Password AutoFill" to activate or deactivate the function.
4. Deactivate use of phone lock code
Press Turn Passcode Off and key in your phone lock code.
5. Return to the Home screen
Slide your finger upwards starting from the bottom of the display to return to the Home screen.
