Mobile guides
Back to Settings & usage
Activate or deactivate use of lock code
The lock code protects the contents of your tablet from unauthorised use. If use of lock code is activated, it needs to be keyed in when you turn on your tablet or when it has been in standby mode.
Step 1 of 10
Press Settings.
Step 2 of 10
Press Touch ID & Passcode.
Step 3 of 10
Press Turn Passcode On.
Step 4 of 10
Follow the instructions on the display to key in a lock code of your own choice and press Require Passcode.
Step 5 of 10
Press the required setting.
Step 6 of 10
Step 7 of 10
To allow deletion of all tablet data after having keyed in an incorrect lock code 10 times in a row, press the indicator next to "Erase Data" until the function is activated.
Step 8 of 10
Press Enable.
Step 9 of 10
Key in the lock code, press Turn Passcode Off and key in the lock code again.
Step 10 of 10
1. Find "Touch ID & Passcode"
Press Settings.
2. Activate use of lock code
Press Enable.
3. Deactivate use of lock code
4. Return to the Home screen
