    Back to Connectivity
    How to set up and use your mobile phone as a Wi-Fi hotspot
    When you use your mobile phone as a Wi-Fi hotspot, you can share your mobile phone's Internet connection with other devices via WLAN. Remember, you need to set up your mobile phone for Internet.
    Step 1 of 15
    Slide two fingers down the display starting from the top edge of your mobile phone.
    Step 2 of 15
    Press More.
    Step 3 of 15
    Press Tethering & portable hotspot.
    Step 4 of 15
    Press Portable Wi-Fi hotspot settings.
    Step 5 of 15
    Press Configure Wi-Fi hotspot.
    Step 6 of 15
    Press the field below "Network name (SSID)" and key in the required name for the Wi-Fi hotspot.
    Step 7 of 15
    Press the drop down list below "Security".
    Step 8 of 15
    If you don't want to password protect your hotspot:
    Press None.
    Step 9 of 15
    Press WPA2 PSK.
    Step 10 of 15
    Step 11 of 15
    Press SAVE.
    Step 12 of 15
    Press the return icon.
    Step 13 of 15
    Press Portable Wi-Fi hotspot until the function is activated.
    Step 14 of 15
    Activate WLAN.
    Step 15 of 15
    1. Find "Tethering & portable hotspot"
    Press More.
    Press None.
    Press WPA2 PSK.
    Press SAVE.
    3. Activate Wi-Fi hotspot
    4. Establish a connection
    Activate WLAN.
    5. Return to the Home screen
