    Back to Connectivity
    How to connect a Bluetooth device to your mobile phone
    Bluetooth is a wireless connection which you can use to transfer files between two devices or to establish a connection to other devices, such as a wireless headset or keyboard.
    Step 1 of 5
    Slide two fingers down the display starting from the top edge of your mobile phone.
    Step 2 of 5
    Press Bluetooth.
    Step 3 of 5
    Press the indicator below "Bluetooth" until the function is activated.
    Step 4 of 5
    Your mobile phone now searches for devices and after a moment, a list of Bluetooth devices within range is displayed.
    Press the required Bluetooth device.
    Follow the instructions on the display to connect the Bluetooth device to your mobile phone.
    The new device is displayed on the list of paired devices.
    Step 5 of 5
    1. Find "Bluetooth"
    Press Bluetooth.
    2. Activate Bluetooth
    4. Return to the Home screen
