    Back to Connectivity
    How to activate or deactivate mobile data
    You can limit your data usage by deactivating mobile data. No connection to the Internet via the mobile network can then be established. You can still use WLAN even though mobile data is deactivated.
    Step 1 of 4
    Slide two fingers down the display starting from the top edge of your mobile phone.
    Step 2 of 4
    Press Data usage.
    Step 3 of 4
    Press Mobile data to activate or deactivate the function.
    Step 4 of 4
    1. Find "Data usage"
    Press Data usage.
    2. Activate or deactivate mobile data
    3. Return to the Home screen
