Login/account box
Mobile guides
Back to Connectivity
How to activate or deactivate data roaming
You can limit your data usage when abroad by deactivating data roaming. No connection to the Internet via the mobile network when abroad can then be established. You can still use WLAN even though data roaming is deactivated.
Step 1 of 6
Slide two fingers down the display starting from the top edge of your mobile phone.
Step 2 of 6
Press More.
Step 3 of 6
Press Mobile networks.
Step 4 of 6
Step 5 of 6
If you activate data roaming:
Press OK to confirm.
Step 6 of 6
1. Find "Mobile networks"
Press More.
3. Return to the Home screen
