    Back to Settings & usage
    How to activate or deactivate use of PIN
    The PIN protects your SIM from unauthorised use should your mobile phone get stolen. If use of PIN is activated, it needs to be keyed in when you turn on your mobile phone.
    Step 1 of 8
    Step 2 of 8
    Step 3 of 8
    Step 4 of 8
    Press Other security settings.
    Step 5 of 8
    Press Set up SIM card lock.
    Step 6 of 8
    Press Lock SIM card to activate or deactivate the function.
    Step 7 of 8
    Key in your PIN and press OK.
    Step 8 of 8
    1. Find "Set up SIM card lock"
    3. Return to the Home screen
