    Back to Settings & usage
    How to activate or deactivate use of phone lock code
    Step 1 of 11
    Step 2 of 11
    Step 3 of 11
    Step 4 of 11
    Press Iris Scanner.
    Step 5 of 11
    Press CONTINUE.
    Step 6 of 11
    Step 7 of 11
    Press CONTINUE.
    Step 8 of 11
    Follow the instructions on the display to create the phone lock code using iris scanner.
    Step 9 of 11
    Press Screen lock type.
    Step 10 of 11
    Key in the current phone lock code and press None.
    Step 11 of 11
    1. Find "Lock screen and security"
    2. Create phone lock code using iris scanner
    Press Iris Scanner.
    Press CONTINUE.
    Press CONTINUE.
    4. Return to the Home screen
