    I can't use WLAN
    Cause 3 of 6: You're not connected to a WLAN
    You can't access the Internet using WLAN, if you're not connected to a WLAN.
    Solution: Establish connection to a WLAN.
    Step 1 of 6
    Step 2 of 6
    Press Wi-Fi.
    Step 3 of 6
    Press the indicator below "Wi-Fi" until the function is activated.
    Step 4 of 6
    Press the required WLAN.
    Step 5 of 6
    Press CONNECT.
    Step 6 of 6
    1 Find " Wi-Fi"
    Press Wi-Fi.
    2 Activate WLAN
    3 Connect to WLAN
    Press CONNECT.
    4 Return to the Home screen
