    I can't use WLAN
    Cause 2 of 6: You're connected to a WLAN but you're not logged on
    Some WLANs require that you log on.
    Solution: Open the browser on your mobile phone and try to load a website. The browser is directed to the start page of the WLAN. Follow the instructions to log on. If you can't log on to the WLAN, deactivate WLAN on your mobile phone and connect to the Internet using the mobile network.
    Step 1 of 10
    Press Internet.
    Step 2 of 10
    Press the address bar.
    Step 3 of 10
    Key in the address of the required website and press Go.
    Step 4 of 10
    Press Bookmarks.
    Step 5 of 10
    Press ADD.
    Step 6 of 10
    Edit the name of the bookmark and press SAVE.
    Step 7 of 10
    Press the Return key.
    Step 8 of 10
    Press Bookmarks.
    Step 9 of 10
    Press the required bookmark.
    Step 10 of 10
    1 Find "Internet"
    Press Internet.
    2 Enter a web address
    3 Add the current website to your bookmarks
    Press Bookmarks.
    Press ADD.
    4 Go to a bookmark
    Press Bookmarks.
    5 Return to the Home screen
