    I can't use tethering on my mobile phone
    Cause 1 of 1: Your computer and mobile phone haven't been correctly set up for tethering
    You need to set up your computer and mobile phone correctly before you can use tethering.
    Solution: Set up your mobile phone and computer for tethering.
    Step 1 of 5
    Step 2 of 5
    Step 3 of 5
    Press Mobile hotspot and tethering.
    Step 4 of 5
    Press USB tethering until the function is activated.
    Step 5 of 5
    An Internet connection from your computer via your mobile phone is automatically established.
    When the connection is established, you can access the Internet from your computer.
    1 Connect your mobile phone to the computer
    2 Activate tethering
    3 Establish connection
