    I can't use my mobile phone as a Wi-Fi hotspot
    Cause 2 of 2: Your mobile phone hasn't been correctly set up as a Wi-Fi hotspot
    You can't use your mobile phone as a Wi-Fi hotspot if it hasn't been set up correctly.
    Solution: Set up your mobile phone as a Wi-Fi hotspot.
    Step 1 of 14
    Step 2 of 14
    Press Mobile hotspot and tethering.
    Step 3 of 14
    Press Mobile hotspot.
    Step 4 of 14
    Press MORE.
    Step 5 of 14
    Press Configure Mobile hotspot.
    Step 6 of 14
    Key in the required name for the Wi-Fi hotspot.
    Press the drop down list below "Security".
    Step 7 of 14
    If you don't want to password protect your hotspot:
    Press Open.
    Step 8 of 14
    Press WPA2 PSK.
    Step 9 of 14
    Step 10 of 14
    Press SAVE.
    Step 11 of 14
    Press the indicator below "Mobile hotspot" until the function is activated.
    Step 12 of 14
    If WLAN is activated:
    Press OK.
    Step 13 of 14
    Activate WLAN.
    Step 14 of 14
    1 Find " Configure Mobile hotspot"
    Press MORE.
    2 Select Wi-Fi hotspot settings
    Press Open.
    Press WPA2 PSK.
    Press SAVE.
    3 Activate Wi-Fi hotspot
    Press OK.
    4 Establish a connection
    Activate WLAN.
    5 Return to the Home screen
