Login/account box
Mobile guides
I can't use my mobile phone as a Wi-Fi hotspot
Cause 1 of 2: An incorrect password has been entered on the connected device
The password used on your mobile phone needs to entered on the device you want to connect from.
Solution: Key in the correct password.
Step 1 of 14
Step 2 of 14
Press Mobile hotspot and tethering.
Step 3 of 14
Press Mobile hotspot.
Step 4 of 14
Press MORE.
Step 5 of 14
Press Configure Mobile hotspot.
Step 6 of 14
Key in the required name for the Wi-Fi hotspot.
Press the drop down list below "Security".
Step 7 of 14
If you don't want to password protect your hotspot:
Press Open.
Step 8 of 14
Press WPA2 PSK.
Step 9 of 14
Step 10 of 14
Press SAVE.
Step 11 of 14
Press the indicator below "Mobile hotspot" until the function is activated.
Step 12 of 14
If WLAN is activated:
Press OK.
Samsung Galaxy S7
Step 13 of 14
Activate WLAN.
Step 14 of 14
1 Find " Configure Mobile hotspot"
Press MORE.
2 Select Wi-Fi hotspot settings
Press Open.
Press WPA2 PSK.
Press SAVE.
3 Activate Wi-Fi hotspot
Press OK.
4 Establish a connection
Activate WLAN.
Samsung Galaxy S7
5 Return to the Home screen
