    Cause 10 of 10: The phone lock code is activated
    The phone lock code is used to protect your mobile phone from unauthorised use. When the phone lock code is activated, it needs to be entered every time you turn on your mobile phone.
    Solution: Key in the phone lock code. You can now deactivate the phone lock code. If you've forgotten the phone lock code, contact the manufacturer for assistance.
    Step 1 of 25
    Step 2 of 25
    Step 3 of 25
    Press Screen lock type.
    Step 4 of 25
    You can create several types of phone lock codes. The steps below describe three examples:
    Create phone lock code using a pattern, go to 2a.
    Create phone lock code using a PIN, go to 2b.
    Create phone lock code using your fingerprint, go to 2c.
    Step 5 of 25
    Press Pattern.
    Step 6 of 25
    Press and drag a point to connect at least four points.
    Step 7 of 25
    Press CONTINUE.
    Repeat the selected phone lock code to confirm.
    Step 8 of 25
    Press CONFIRM.
    Step 9 of 25
    Press the required setting.
    Step 10 of 25
    Press DONE.
    Step 11 of 25
    To add a fingerprint:
    Press SET UP.
    Follow the instructions on the display to add a fingerprint.
    Step 12 of 25
    To continue without adding a fingerprint:
    Press LATER.
    Step 13 of 25
    Press PIN.
    Step 14 of 25
    Key in the required phone lock code and press CONTINUE.
    Step 15 of 25
    Key in the phone lock code again and press OK.
    Step 16 of 25
    Step 17 of 25
    Press DONE.
    Step 18 of 25
    Press SET UP.
    Step 19 of 25
    Press LATER.
    Step 20 of 25
    Press Fingerprints.
    Step 21 of 25
    Press the required phone lock code.
    Follow the instructions on the display to create the required phone lock code.
    Step 22 of 25
    Step 23 of 25
    Press DONE.
    Step 24 of 25
    Press None.
    Step 25 of 25
    1 Find " Screen lock type"
    2 Select option
    3 2a - Create phone lock code using a pattern
    Press Pattern.
    Press CONTINUE.
    Press CONFIRM.
    Press DONE.
    Press SET UP.
    Press LATER.
    4 2b - Create phone lock code using a PIN
    Press PIN.
    Press DONE.
    Press SET UP.
    Press LATER.
    5 2c - Create phone lock code using your fingerprint
    Press Fingerprints.
    Press DONE.
    6 Deactivate use of phone lock code
    Press None.
    7 Return to the Home screen
