Login/account box
Mobile guides
Cause 9 of 10: Your mobile phone isn't turned on correctly
Your mobile phone won't turn on if it's not done correctly.
Solution: Turn on your mobile phone correctly.
Step 1 of 5
Press On/Off until your mobile phone is turned on.
Step 2 of 5
Key in your PIN and press OK.
If your mobile phone rejects your SIM:
Contact your distributor or service provider where you bought your mobile phone.
Step 3 of 5
Press and hold On/Off.
Step 4 of 5
Press the power off icon.
Step 5 of 5
1 Turn on your mobile phone
2 Enter PIN
3 Turn off your mobile phone
