    Cause 7 of 10: Your mobile phone is locked to another service provider
    If your mobile phone is locked to another service provider and you're trying to use a Swisscom SIM card, the display will tell you that your SIM card is invalid.
    Solution: Before you can use a Swisscom SIM card, you need to unlock your mobile phone using an unlock code. To get the unlock code, contact the service provider that locked your mobile phone.
