Login/account box
Mobile guides
Cause 1 of 10: The battery is flat
If the battery is flat, you can't turn on your mobile phone.
Solution: Charge the battery.
Step 1 of 3
Connect the charger to the phone socket and to a wall socket.
Step 2 of 3
When the battery charging icon is displayed, charging is in progress.
Samsung Galaxy S7
Step 3 of 3
When the battery is fully charged, you can remove the charger from the wall socket and your mobile phone.
1 Connect the charger to your mobile phone
2 End charging
Samsung Galaxy S7
