    I can't send and receive MMS
    Cause 3 of 5: The MMS is written incorrectly
    The MMS can't be sent if it's written incorrectly.
    Solution: Write an MMS correctly.
    Step 1 of 16
    Press Messages.
    Step 2 of 16
    Press the new message icon.
    Step 3 of 16
    Press the required contact.
    Step 4 of 16
    Press the text input field.
    Write the text for your MMS.
    Step 5 of 16
    Press the attachment icon.
    Step 6 of 16
    Press OTHER.
    Insert a picture, go to 5a.
    Insert a video clip, go to 5b.
    Insert an audio file, go to 5c.
    Step 7 of 16
    Press Image.
    Go to the required folder.
    Step 8 of 16
    Press the required picture to select it.
    Step 9 of 16
    Press DONE.
    Step 10 of 16
    Press Video.
    Step 11 of 16
    Press the required video clip.
    Step 12 of 16
    Press Audio.
    Step 13 of 16
    Press the required audio file.
    Step 14 of 16
    Press DONE.
    Step 15 of 16
    Press SEND when you've finished your MMS.
    Step 16 of 16
    1 Find "Messages"
    Press Messages.
    2 Write MMS
    3 Select the recipient
    4 Write the text
    5 Insert pictures, video clips and audio files
    Press OTHER.
    6 5a - Insert a picture
    Press Image.
    Press DONE.
    7 5b - Insert a video clip
    Press Video.
    8 5c - Insert an audio file
    Press Audio.
    Press DONE.
    9 Send the MMS
    10 Return to the Home screen
