    I can't receive messages on my COMBOX®
    Cause 1 of 1: Voice calls aren't diverted to your COMBOX®
    Missed calls are only diverted to your COMBOX® if the correct settings have been selected. You can change the settings in the phone menu.
    Solution: Divert calls to your COMBOX®.
    Step 1 of 13
    Press Phone.
    Step 2 of 13
    Press MORE.
    Step 3 of 13
    Press Settings.
    Step 4 of 13
    Press More settings.
    Step 5 of 13
    Press Call forwarding.
    Step 6 of 13
    Press Voice call.
    Step 7 of 13
    The current settings are displayed.
    Step 8 of 13
    Always forward
    Step 9 of 13
    Forward when busy
    Step 10 of 13
    Forward when unanswered
    Step 11 of 13
    Forward when unreachable
    Step 12 of 13
    Key in +4186(area code)(your phone number) and press ENABLE.
    Step 13 of 13
    1 Find "Voice call"
    Press Phone.
    Press MORE.
    Press Settings.
    Press Voice call.
    2 Select divert type
    Always forward
    Forward when busy
    3 Divert calls to COMBOX®
    4 Return to the Home screen
