    I can't make voice calls
    Cause 5 of 9: Your mobile phone is set to connect to 4G networks only
    If your mobile phone is set to connect to 4G networks only, it can't find a network if you're in an area with poor or no 4G network coverage.
    Solution: Change network mode allowing your mobile phone to connect to both 2G, 3G and 4G networks.
    Step 1 of 5
    Step 2 of 5
    Press Mobile networks.
    Step 3 of 5
    Press Network mode.
    Step 4 of 5
    Press 4G/3G/2G (auto connect), 3G/2G (auto connect), 3G only or 2G only.
    Step 5 of 5
    1 Find " Network mode"
    Press Network mode.
    2 Select network mode
    3 Return to the Home screen
