    Back to Calls & contacts
    How to activate or deactivate call barring
    You can block certain types of calls such as incoming calls when you're abroad.
    Step 1 of 13
    Press Phone.
    Step 2 of 13
    Press MORE.
    Step 3 of 13
    Press Settings.
    Step 4 of 13
    Press More settings.
    Step 5 of 13
    Press Call barring.
    Step 6 of 13
    Press Voice call.
    Step 7 of 13
    All outgoing calls
    Step 8 of 13
    International calls
    Step 9 of 13
    International calls except home
    Step 10 of 13
    All incoming calls
    Step 11 of 13
    All incoming calls when roaming
    Step 12 of 13
    Key in your call barring password and press OK to activate or deactivate the function.
    Step 13 of 13
    1. Find "Voice call"
    Press Phone.
    Press MORE.
    Press Settings.
    Press Call barring.
    Press Voice call.
    2. Select barring option
    All outgoing calls
    International calls
    All incoming calls
    3. Activate or deactivate call barring
    4. Return to the Home screen
