    Samsung Galaxy S7 edge
    I can't use WLAN
    Cause 6 of 6: The WLAN is using a hidden SSID
    If the WLAN is using a hidden SSID, you won't find the WLAN when searching for available WLANs. You can only connect to a WLAN using a hidden SSID if you know the correct SSID.
    Solution: Key in SSID and security settings manually on your mobile phone.
