    Samsung Galaxy S7 edge
    Cause 6 of 10: Your mobile phone hasn't been assembled correctly
    If your mobile phone hasn't been assembled correctly, you can't turn on your mobile phone.
    Solution: Make sure your mobile phone has been assembled correctly.
    Step 1 of 4
    Insert the opener for the SIM holder into the small hole in the SIM holder at the top of your mobile phone.
    Step 2 of 4
    Remove the SIM holder from your mobile phone.
    Step 3 of 4
    Turn your SIM so the angled corner of your SIM matches the angled corner of the SIM holder.
    Place your SIM in the SIM holder.
    Step 4 of 4
    Slide the SIM holder into your mobile phone.
    1 Remove the SIM holder
    2 Insert your SIM
    3 Insert the SIM holder
