    Samsung Galaxy S7 edge
    Cause 1 of 10: The battery is flat
    If the battery is flat, you can't turn on your mobile phone.
    Solution: Charge the battery.
    Step 1 of 3
    Connect the charger to the phone socket and to a wall socket.
    Step 2 of 3
    When the battery charging icon is displayed, charging is in progress.
    Step 3 of 3
    When the battery is fully charged, you can remove the charger from the wall socket and your mobile phone.
    1 Connect the charger to your mobile phone
    2 End charging
