    Samsung Galaxy S7 edge
    I can't install apps
    Cause 3 of 3: You haven't activated a Google account on your mobile phone
    If you haven't activated a Google account on your mobile phone, you can't install apps.
    Solution: Activate a Google account on your mobile phone.
    Step 1 of 10
    Step 2 of 10
    Press Accounts.
    Step 3 of 10
    Press Add account.
    Step 4 of 10
    Press Google.
    Step 5 of 10
    Press the text input field and key in the username for your Google account.
    Step 6 of 10
    Press NEXT.
    Step 7 of 10
    Press the text input field and key in the password for your Google account.
    Step 8 of 10
    Press NEXT.
    Step 9 of 10
    Press ACCEPT.
    Follow the instructions on the display to select settings for your Google account.
    Step 10 of 10
    1 Find " Google"
    Press Accounts.
    Press Add account.
    Press Google.
    2 Activate your Google account
    Press NEXT.
    Press NEXT.
    Press ACCEPT.
    3 Return to the Home screen
