Login/account box
Mobile guides
Samsung Galaxy S7 edge
I can't install apps
Cause 1 of 3: The required app isn't available in your country
If the app isn't available in your country, you can't install it.
Solution: Search for similar apps or wait for the app to become available in your country.
Step 1 of 10
Press Apps.
Step 2 of 10
Press Play Store.
Step 3 of 10
Press the search field.
Step 4 of 10
Key in the name of the required app and press the search icon.
Step 5 of 10
Press the required app.
Step 6 of 10
To install a free app:
Press INSTALL.
Step 7 of 10
To buy an app:
Press the price.
Step 8 of 10
Follow the instructions on the display to install the app.
Press the Home key to return to the Home screen.
Step 9 of 10
Press Apps.
Step 10 of 10
Press the app you've just installed.
Follow the instructions on the display to use the app.
1 Find "Play Store"
Press Apps.
Press Play Store.
2 Find app
3 Install the app
Press INSTALL.
To buy an app:
Press the price.
4 Use the app
Press Apps.
