Login/account box
Mobile guides
Samsung Galaxy S7 edge
I can't send and receive SMS
Cause 3 of 3: The SMS is written incorrectly
The SMS can't be sent if it's written incorrectly.
Solution: Write an SMS correctly.
Step 1 of 6
Press Messages.
Step 2 of 6
Press the new message icon.
Step 3 of 6
Press the required contact.
Step 4 of 6
Press the text input field.
Write the text for your SMS.
Step 5 of 6
Press SEND when you've written your SMS.
Step 6 of 6
1 Find "Messages"
Press Messages.
2 Write SMS
3 Enter the recipient
4 Write the text
5 Send the SMS
6 Return to the Home screen
