Login/account box
Mobile guides
Samsung Galaxy S7 edge
I can't send and receive SMS
Cause 2 of 3: The message centre number is incorrect
The message centre ensures that your SMS is sent to the recipient. If the message centre number is incorrect, you can't send SMS.
Solution: Enter the correct message centre number.
Step 1 of 8
Press Messages.
Step 2 of 8
Press MORE.
Step 3 of 8
Press Settings.
Step 4 of 8
Press More settings.
Step 5 of 8
Press Text messages.
Step 6 of 8
Press Message centre.
Step 7 of 8
Key in +41794999000 and press SET.
Step 8 of 8
1 Find "Text messages"
Press Messages.
Press MORE.
Press Settings.
2 Save the message centre number
3 Return to the Home screen
