Login/account box
Mobile guides
Samsung Galaxy S7 edge
I can't send and receive MMS
Cause 5 of 5: Your mobile phone hasn't been correctly set up for MMS
If your mobile phone hasn't been correctly set up for MMS, you can't send and receive MMS.
Solution: Set up your mobile phone for MMS.
Step 1 of 28
Step 2 of 28
Press Mobile networks.
Step 3 of 28
Press Access Point Names.
Step 4 of 28
Press ADD.
Step 5 of 28
Press Name.
Step 6 of 28
Key in Swisscom MMS and press OK.
Step 7 of 28
Press APN.
Step 8 of 28
Key in event.swisscom.ch and press OK.
Step 9 of 28
Press MMSC.
Step 10 of 28
Key in http://mms.natel.ch:8079 and press OK.
Step 11 of 28
Press MMS proxy.
Step 12 of 28
Key in 192.168.210.2 and press OK.
Step 13 of 28
Press MMS port.
Step 14 of 28
Key in 8080 and press OK.
Step 15 of 28
Press MCC.
Step 16 of 28
Key in 228 and press OK.
Step 17 of 28
Press MNC.
Step 18 of 28
Key in 01 and press OK.
Step 19 of 28
Press Authentication type.
Step 20 of 28
Press None.
Step 21 of 28
Press APN type.
Step 22 of 28
Key in mms and press OK.
Step 23 of 28
Press Bearer.
Step 24 of 28
Press Unspecified until the function is activated.
Step 25 of 28
Press OK.
Step 26 of 28
Press MORE.
Step 27 of 28
Press Save.
Step 28 of 28
1 Find " Access Point Names"
2 Set up a new data connection
Press ADD.
3 Enter a data connection name
Press Name.
4 Enter APN
Press APN.
5 Enter the MMS server
Press MMSC.
6 Enter the IP address
Press MMS proxy.
7 Enter the port number
Press MMS port.
8 Enter the country code
Press MCC.
9 Enter the network code
Press MNC.
10 Select the authentication type
Press None.
11 Select the APN type
Press APN type.
12 Select data bearer
Press Bearer.
Press OK.
13 Save the data connection
Press MORE.
Press Save.
14 Return to the Home screen
