    Samsung Galaxy S7 edge
    I can't send and receive MMS
    Cause 4 of 5: Mobile data is deactivated on your mobile phone
    If mobile data is deactivated on your mobile phone, you can't send and receive MMS.
    Solution: Activate mobile data.
    Step 1 of 2
    Press Mobile data to activate or deactivate the function.
    Step 2 of 2
    1 Activate or deactivate mobile data
    2 Return to the Home screen
