    Samsung Galaxy S7 edge
    I can't send and receive MMS
    Cause 2 of 5: You're abroad and data roaming is deactivated on your mobile phone
    If you're abroad and data roaming is deactivated on your mobile phone, you can't send and receive MMS.
    Solution: Activate data roaming.
    Step 1 of 4
    Step 2 of 4
    Press Mobile networks.
    Step 3 of 4
    Step 4 of 4
    1 Find " Mobile networks"
    2 Activate or deactivate data roaming
    3 Return to the Home screen
