    Samsung Galaxy S7 edge
    I can't send and receive e-mails
    Cause 3 of 3: Your mobile phone hasn't been correctly set up for e-mail
    If your mobile phone hasn't been correctly set up for e-mail, you can't send and receive e-mail.
    Solution: Set up your mobile phone for e-mail.
    Step 1 of 32
    Press Apps.
    Step 2 of 32
    Press Samsung.
    Step 3 of 32
    Press Email.
    Step 4 of 32
    Press ADD NEW ACCOUNT.
    Step 5 of 32
    Press Email address and key in your Swisscom e-mail address.
    Step 6 of 32
    Press Password and key in the password for your Swisscom e-mail account.
    Step 7 of 32
    Press SIGN IN.
    Step 8 of 32
    Press MORE.
    Step 9 of 32
    Press Settings.
    Step 10 of 32
    Press the name of the e-mail account you've just set up.
    Step 11 of 32
    Press Sync account to activate the function.
    Step 12 of 32
    Press Account name and key in the required name.
    Step 13 of 32
    Press OK.
    Step 14 of 32
    Press Your name and key in the required sender name.
    Step 15 of 32
    Press OK.
    Step 16 of 32
    Press Sync schedule.
    Step 17 of 32
    Press Set sync schedule.
    Step 18 of 32
    Press Auto (when received), Manual or the required period.
    Step 19 of 32
    Press Sync data while roaming.
    Step 20 of 32
    Press Manual or Use above settings.
    Step 21 of 32
    Press Peak schedule to activate or deactivate the function.
    Step 22 of 32
    If you activate the function:
    Press Set peak schedule.
    Step 23 of 32
    Step 24 of 32
    Press the required days below "Peak days".
    Step 25 of 32
    Press the field next to "Start time".
    Step 26 of 32
    Slide your finger up or down on hour and minute.
    Step 27 of 32
    Press SET.
    Step 28 of 32
    Press the field next to "End time".
    Step 29 of 32
    Step 30 of 32
    Press SET.
    Step 31 of 32
    Press the Return key.
    Step 32 of 32
    1 Find "ADD NEW ACCOUNT"
    Press Apps.
    Press Samsung.
    Press Email.
    2 Enter e-mail address
    3 Enter password
    Press SIGN IN.
    4 Activate synchronisation of e-mails
    Press MORE.
    Press Settings.
    5 Enter an account name
    Press OK.
    6 Enter the sender name
    Press OK.
    7 Select settings for retrieval of new e-mails
    8 Select setting for synchronisation when roaming
    9 Select setting for synchronisation during peak hours
    Press SET.
    Press SET.
    10 Return to the Home screen
