    Samsung Galaxy S7 edge
    I can't receive voice calls
    Cause 1 of 2: Your mobile phone isn't responding
    Your mobile phone may not respond due to overload or errors in the operating system.
    Solution: Restart your mobile phone.
    Step 1 of 1
    Press and hold On/Off and the Bottom volume key simultaneously until your mobile phone is restarted.
    1 Restart your mobile phone
