    Samsung Galaxy S7 edge
    I can't make voice calls
    Cause 8 of 9: Flight mode is activated
    If flight mode is activated, your mobile phone's transmitting functions are deactivated. This means that you can't make or receive calls.
    Solution: Deactivate flight mode.
    Step 1 of 1
    Press Flight mode to activate or deactivate the function.
    1 Activate or deactivate flight mode
