    Samsung Galaxy S7 edge
    I can't make voice calls
    Cause 6 of 9: You price plan has been suspended due to non-payment
    You'll be notified if your price plan has been suspended when you try to make a call.
    Solution: Log on to Swisscom Customer Centre for more help.
