    Samsung Galaxy S7 edge
    I can't make voice calls
    Cause 3 of 9: There's an error at the receiving end
    If you're having problems calling a specific number, the error might be at the receiving end.
    Solution: Try calling another number. If you can call another number, the error is probably at the receiving end.
