    Samsung Galaxy S7 edge
    I can't check my COMBOX®
    Cause 2 of 3: Your COMBOX® number isn't saved on your mobile phone
    To check your COMBOX®, you need to save your COMBOX® number on your mobile phone.
    Solution: Save your COMBOX® number.
    Step 1 of 7
    Press Phone.
    Step 2 of 7
    Press MORE.
    Step 3 of 7
    Press Settings.
    Step 4 of 7
    Press Voicemail settings.
    Step 5 of 7
    Press Voicemail number.
    Step 6 of 7
    Key in +41794997979 and press OK.
    Step 7 of 7
    1 Find "Voicemail number"
    Press Phone.
    Press MORE.
    Press Settings.
    2 Save your COMBOX® number
    3 Return to the Home screen
