    Samsung Galaxy S7 edge
    Back to Multimedia & apps
    How to activate or deactivate GPS
    You mobile phone can determine your geographical position using GPS (Global Positioning System). The information about your position is used by a number of applications on you mobile phone, such as navigation, the search function and the weather forecast.
    Step 1 of 10
    Step 2 of 10
    Press Privacy and safety.
    Step 3 of 10
    Press Location.
    Step 4 of 10
    Press the indicator below "Location" to activate or deactivate the function.
    Step 5 of 10
    If you activate the function:
    Press Locating method.
    Proceed to step 3.
    If you deactivate the function:
    Proceed to step 4.
    Step 6 of 10
    Activate satellite-based and network-based GPS, go to 3a.
    Activate network-based GPS, go to 3b.
    Activate satellite-based GPS, go to 3c.
    Step 7 of 10
    Press GPS, Wi-Fi, and mobile networks.
    Step 8 of 10
    Press Wi-Fi and mobile networks.
    Step 9 of 10
    Press GPS only.
    Step 10 of 10
    1. Find " Location"
    Press Location.
    2. Activate or deactivate GPS
    Proceed to step 3.
    Proceed to step 4.
    3. Select option
    4. 3a - Activate satellite-based and network-based GPS
    5. 3b - Activate network-based GPS
    6. 3c - Activate satellite-based GPS
    Press GPS only.
    7. Return to the Home screen
