    Samsung Galaxy S7 edge
    Back to Messaging & Internet
    How to write and send e-mails
    You can send and receive e-mails from your e-mail accounts. Remember, you need to set up your mobile phone for e-mail.
    Step 1 of 16
    Press Apps.
    Step 2 of 16
    Press Samsung.
    Step 3 of 16
    Press Email.
    Step 4 of 16
    Press the drop down list in the top left corner of the display.
    Step 5 of 16
    Press the required e-mail account.
    Step 6 of 16
    Press the new e-mail icon.
    Step 7 of 16
    Press the field next to "To" and key in the first letters of the required contact.
    Step 8 of 16
    Press the required contact.
    Repeat the procedure to add more recipients.
    Step 9 of 16
    Press Subject and key in a subject for the e-mail.
    Step 10 of 16
    Press the text input field.
    Write the text for your e-mail.
    Step 11 of 16
    Press ATTACH.
    Step 12 of 16
    Press OTHER.
    Go to the required folder.
    Step 13 of 16
    Press the required file.
    Step 14 of 16
    Press DONE.
    Step 15 of 16
    Press SEND when you've finished your e-mail.
    Step 16 of 16
    1. Find "Email"
    Press Apps.
    Press Samsung.
    Press Email.
    2. Select e-mail account
    3. Write the e-mail
    4. Select recipient
    5. Enter subject
    6. Write the text
    7. Attach file
    Press ATTACH.
    Press OTHER.
    Press DONE.
    8. Send the e-mail
    9. Return to the Home screen
